90 hp mercury stator/trigger issues
johnhoyt72032
Trying to figure out why when I hook up my recitfier my engine will not advance throttle, but when I disconnect it the engine will run top end perfect low end mid all around perfect. But would love to be able to charge my batteries. Any idea on what the problem maybe? Thanks My engine is a 1984 90Hp Mercury Inline 6 cyl.
CharlieB
Re: 90 hp mercury stator/trigger issues
One of the tests to determine a high speed ignition problem is to disconnect the rectifier.
When that clears up the misfire chances are the rectifier is bad, causing strange EMF within the stator and lowering voltage output of the high speed ignition coils.
Take the rectifier off and test continuity of each yellow to the red, then reverse your leads and retest. You should have continuity in only one direction. Repeat each yellow to ground and red to ground.
From what you have already proven, it is a pretty safe bet that your rectifier is done.
johnhoyt72032
we'll I have replaced the rectifer and still have the same problem charges like hell but wont go over 20 miles an hour
Faztbullet
Broken with in charging wiring inside stator,
ENSIGN
If you're using a tach disconnect it and give it a try
CharlieB
DVA test the stator yellow wires.
