90 hp mercury missing on 2 cyl.
roadstarmoney
runs on bottom cyl only at idle. seems to hit sometimes on high rev. can u tell me where eng # is and if reed valves could be the problem. this is and old 90 hp 2 stroke engine with 3 carbs. bought old pontoon boat with this on it. need help.
Bosunsmate
Re: 90 hp mercury missing on 2 cyl.
If reed valves you normally get a spit back or can feel air being pressed back too from engine compression/exhaust
Laddies
Banned
If the engine idles the reeds are OK as they only work at idle and very low RPM, you could have a bad lower seal if you have spark at higher RPM.
