90 hp Johnson Ocean Runner will not start or trim
spiderwilliams
I have a 2001 Johnson Ocean Runner 90 hp that was running fine on the hose. Then after 5 min would not start or trim. Depth finder has power and battery connections are good. I have power at the motor, but can not trace it to a fuse. The trim switch on the side of the motor does not have power. Is there a relay or fuse that could be bad?
Thanks
Chris1956
Re: 90 hp Johnson Ocean Runner will not start or trim
There should be a 20A fuse on the motor, near the starter solenoid. Of course, something is likely causing it to blow. I would look over wiring on motor. Look for a wire rubbing some metal, and then shorting.
spiderwilliams
Thanks, i started looking for the fuse and the raw wires yesterday.
spiderwilliams
I found the blown fuse yesterday. I am looking for a bare wire now.
thanks
Chris1956
I had a melted harness on the port side of the motor, next to where the boat harness plugs into the motor harness. The melted part was the boat harness, vs the motor harness. I also had melted wires at the dashboard where the wires connect to the gauges. I never did figure out what caused it, and I bought the boat that way.
