Re: 90 hp force wont turn over! help!
update... fixed the starter 4 times before it worked for good, 2 times stuck up, one time stuck down, i think its because the nut is loose im not sure if im supposed to tighten it all the way down and torque it, i have a habit of over tightening things.. when the starter engages, its loosens the nut a bit more every time... should it be tightened all the way down? also, i can get her to fire up every time now! i ran it hard with seafoam in it, smoked out the carbs real good, ran well. when i fire it up now it sometimes dies in neutral, sometimes dies when revving, etc.. i know you are all thinking to test the stator (any step by step on how to do that with my multimeter??), but i am convinced it is my kill switch, which still doesnt function properly, and when i keep the button pressed in with my finger (no lanyard with it, i think its supposed to have one, universal lanyard keys do not work, all 6) i can run it forever in any gear and any rpm.... that leads me to believe that its the switch, like i presumed before, i am ordering a new one because they are like 12 bucks... in the mean time, any info on testing my stator? where is my rectifier? how can i test that? you guys are really halping me out this forum is sweet.
