90 HP force problem..
dwci97
90 hp FORCE runs great then it warms up after 20 minutes and wants to cut out and loose power from time to time. Figured it kinda has to be either a bad power pack/coil problem or something in the fuel or fuel line. Any help would be greatly appreciated. <br /><br />Happened last night and did it for a while then it just quit doing it and ran fine the rest of the night?????
revertmastec
Re: 90 HP force problem..
when it starts to lose power try pumping the fuel primer to see if that helps. If it does you have narrowed your problem to fuel delivery.
