90 four stroke problem
11andy11
I have a 2004 yamaha 90 hp four stroke with 35 hours. Last time I took it out it would stall at idle. After numerous attempts to start it, i finally got it to idle. When I throttled up it would stall at about 1100 rpm. When i throttle up and get past that stall point it would max out at about 3500 rpm. Any ideason what my problem might be?
rodbolt
Re: 90 four stroke problem
check compression and spark. test the TPS and inspect the fuel system. most of the problems come from dirty carbs.
rodbolt
oh, the 04 did not have the TPS, that makes it even simpler.<br /> the 4 stroke carb passages are very small and prone to clog.
11andy11
I thought the 2004 was fuel injected. I guess you mean an injector it clogged.
rodbolt
nope 04 was carbed,05 was the first model run of the EFI F90.<br /> thats why a model number is always so nice, it identifies the motor
11andy11
Thanks for the clarification. It looked like carbs to me but I don't know alot about outboards. I have a manual on the way. I am fairly mechanically minded, do you think this is something I should attemp myself or take it to a tech? Thanks again for the help.
rodbolt
well if ya cant tell the difference between EFI and carbs I would suggest a tech. however if you get the factory service manual and the tools essential for carb repair its not difficult just time consuming.
bigbrownbuku
Master Chief Petty Officer
tools will include a balancer which dont come cheap.
rodbolt
11any11<br /> I did not mean to sound sharp but you asked,<br /> the carbs on that four stroke require a manometer to balance,can it be done without it? yep. can it be time consuming and frustrating? yes. the carbs themselves are straight fwd, its the sync of them that can irritate. but withut that model number I cant tell ya a lot about it.
