dankboater
Thread starter- Joined
- May 19, 2009
- 19
Ok so I just got a great deal on a boat that apparently needed a new thrust bearing changed in the lower unit as well as a new spanner nut and a linkage adjustment. The guy said just take the lower unit apart and clean the threads in the housing. So I was like sounds like I should get it checked out from someone just to be sure. So i take it in to a small engine mechanic and he says I need a new seal kit $80.78, Spool Assy $187, Body water pump $45, Imp $33, and about $400 in labor. The mechanic said the lower unit froze bla bla bla... I was like dang $800 bucks wow! So I left and called back the guy who sold me the boat and he said it never froze and swears by it. So What I am wondering is if this sounds like a legit estimate or am I getting fleased by the mechanic or is the seller of the boat lying? All the small engine mechanic did was look inside the lower unit.
