Had a problem a couple weeks ago.
The motor would go to 1/3 throttle and die and just repeat itself. I found a problem in the fuel pump, the diaphragm return spring had fallen over. I put a fuel pump kit in and a carb kit also a water pump kit.
Trying it out today it ran very strong at full throttle. I had to play with the idle some. After trolling for 20 30 minutes I started to go back up river. As I throttled up the motor would die back. Rev up and then die back to idle over and over.
What could be my problem. I replaced all hoses and don't run ethanol fuel. Replaced the plugs.
At a loss
TJ
Pumping the bulb doesn't seem to help.
If it's spark what would cause the motor to rev up and then die back and rev up . Only takes a second or 2 to rev and then die.
At a loss
TJ
