Re: 90 90 evin plugs
Sounds like you need to rebuild the Carbs! May be floats sticking or other crud in them. I say this because you say that you have good spark, which if is truly the case, it can only be fuel related. How did you check for good spark? Should jump at about 1/2" to the block!
