I have a late 1980s or early 1990s johnson 9.9 hp motor. once I start it, it runs for a while then cuts out. The pressure on primer bulb always is gone when the engine dies. after priming it again she starts but dies after short ride. I thought it could be bad primer bulb, so a bought a new one and same problem continues. could it be a bad fuel connector or perhaps fuel pump? someone help, help me, please. I would like to use it this memorial day holiday. I have not repaired the motor myself -- so if it is the fuel pump, is it easy to install. The motor is a pull-start engine.<br /><br />Your help is greatly appreciated.<br /><br />Zman-2
