I bought a new 9.9 Mercury with a Lowe V1467 WT aluminum boat for fishing. The boat weighs in at 262# and is rated for a 20 HP motor max. I picked the 9.9 HP as it allows me to fish lakes in AZ that limit motor size. I live at some 5100' in elevation.
The stock prop had a pitch of 8.5" and with a 600# total load in the boat (including the motor and such) the boat could only get up to 6 MPH measured with a GPS. I found a chart which said that for every 1000' starting at 3000 to reduce the prop pitch by 1". Also, Mercury informed me that I needed to change the pitch on my prop to help the motor rev up for more speed at my altitude and they advised I change my prop out to a 4 blade bigfoot series prop, an 8.75"x 5.5". So I ordered the new prop and took the boat out yesterday to try it again. I did add another 100# to the load with a trolling motor and battery however.
I was amazed that the motor seemed to rev up more than it did but I could still only make some 6 MPH top speed as measured by a GPS.
Everything I have read and been told says that what Mercury told me should correct the problem but it's just not working.
Any ideas?? I would hate to have to change jets every time I change elevations but I may have to?
