9.9 johnston evinrude 1982 impeller
gaz
hi to all , is it a straight forward job to drop off bottom leg to replace impeller and i cant seem to find any imformation on the net relating to my model no j10bacns a web site would be fantastic
tashasdaddy
Re: 9.9 johnston evinrude 1982 impeller
diagrams here, lower unit, exhaust housing. looks like a straight forward drop. should be a 1"x2" plate of the side on the leg, remove cover, remove the bottom screw, don't drop. then remove the bolts that hold the lower unit, should drop right out. besure to realign everything, and just the reverse.
when reattaching the shift linkage the screw has to got thru the indentation.
jbehr
If you look in the Engine Frequently Asked Questions forum and scroll down to "9.9/15 hp OMC engines by the Machinist" posted in Feb. '06 you can find a ton of info on your motor and instructions on how to change the impeller. The Machinists site is really great for a guy who is new to working on or operating these motors. Good luck.
gaz
hi thanks for reply and sorry for this late message as i have just got to the grips off using this forum still cant use it but so far so good i tryed faq and cant get my head round how to use it, help an irishman out and tell me how to use it, ta
Vic.S
The FAQs that jbehr refers to are not the forum FAQs which are probably what you found but the "engine FAQs". Go to the "repair and maintenance " index, the Engine FAQs are the first item on there, go to those and scroll down until you come to the post on OMC 9.9s.
If you still cant find it then its http://forums.iboats.com/showthread.php?t=158087
Also useful are the engine diagrams at http://epc.brp.com/default.aspx?brands=ej&lang=e I think Tashasdaddy meant to put that in his post. Bu??ered if I know what is picture shows though
gaz
hi from ireland and many thanks for imformation,droped leg and checked impeller, took top plate of and checked thermostat in kettel and it works,blew up pipe from impeller housing could hear it loud and clear ,had tell tale off and cleaned out right to the head put pipe back on and could not blow up it seems blocked can the water jacket block that well and also what is the three pinned female connector on side off engine caseing for?thanks for all help so far,this engine has been sitting in a big bag for 10 years and looks brand new old gentleman who sold it to me said it had about 8hours of use, thanks again gaz from ireland
Vic.S
Any part of the cooling system can block. The channels around the head seem particularly vulnerable but it should not be a problem with only a few hours use.
I think you will find that the three pin connector is an AC output for lighting. I guess your engine does not have a rectifier for battery charging. Only fitted as standard on electric start models.
If I am right you can connect 12volt lights up to 30watts between the yellow/grey wire and the yellow wire and another 30watts between the yellow grey and the yellow/blue.
Sorry i don't know the pin layout on the connector. You should be able to buy a plug to fit it.
gaz
Re: 9.9 johnston evinrude 1982 oil leak from prop
hi again thanks to this forum and all the people that help every thing is good with my engine but have new problem oil leakingout behind prop is this an oil seal problem and what kind off job to do, thanks again to all that replyed
Vic.S
Yes it is the seals on the prop shaft. You need two seals but note carefully which way round they are fitted (one keeps the oil in and the other keeps the water out) and an O ring for the housing.
You'll see the parts on the parts diagram in the BRP Parts catalogue
