9.9 johnson question #2
mikeforan
I cleaned the carb / new gaskets etc. (carb kit) and still nothing... <br />Pulled both plugs and turned the flywheel and see no spark!<br />I had a power pack replaced last season... what could be wrong.. could both power packs be bad? I suspect some other electric problem... what's under the flywheel? it's a 1989 model<br />Thanks!!!<br /><br />MY LAST QUESTION:<br />A little history... I bought my boat mid summer last year from my neighbor... it was slow, after servicing we found that only one plug was firing, changed the power pack and all was great.<br />I let it sit all winter and fired it up in the yard ( only 2 pulls! with muffs) the other day and it sounded great.<br />Well, I took it out on the water, started after 7 or 8 pulls and ran nicely for about 15 minutes ( 10 mins at no wake and 5 mins at full throttle) when slowing down at another slow no wake area , it stalled and didn't want to start again. 20 mins later it fired up again after a few pulls but stalled out again after just a few mins. - never to restart again.<br />I sprayed starter fluid into carb - nothing!<br />I changed the plugs - nothing!<br />I'm not sure if its a fuel problem - any suggestions?<br />or an electrical issue - any ideas? can I disable the kill switch... is that a possible solution?<br />I'd like to work on it myself rather than bringing it into the shop... which could take weeks!<br />Thanks for your help! <br /><br />THE ANSWER I GOT:<br />Check for a spark at both plugs.<br />Fresh fuel?<br />Gas cap vent screw open?<br />Lever in neutral position?<br />Don't use starter fluid. There is no oil in it.<br />Do you know the year or do you have the model number? <br />You really should get a manual for it. Check this link. <br />Good luck!
Solittle
Re: 9.9 johnson question #2
Did you ground the plugs when you tested for spark?
BF
Was it pumping water alright when it was running? Maybe it overheated and toasted some electrical bit (again). Maybe overheating is what caused your first bout of electrical problems (?)
