whistler66
Thread starter- Joined
- Nov 27, 2008
- 52
Sorry I don't know the yr as I'm posting for a friend. This is a grey Johnson with grey, black, maybe some white in the name decal on the cowling. I don't think it over 5-7 yrs old? Has had constant trouble with idle. Had had carb rebuilt 3 times. 2 times in the last 6 months by a reputable dealer. Each time dealer blames bad gas? Friend mixes gas properly and uses a high tier brand gas. His boat is used enough that he shouldn't be having an "old gas" problem. The 2nd time he had the Carb rebuilt it did set for a month prior to use and then it would'nt start at all. Another trip to the shop got another rebuild.....but still a no idle. I had failed to mention this machine had almost refused to idle from early on as my friend has owned it since new. It might idle occasionally but not often. This has not been a bother to my friend as the way he uses it! Starts it, travels to point A......lets it die and anchors off.....Then repeat process to point B if fish are not biting etc.. It will start on the coldest mornings in no more than 2-3 pulls and run as long as some throttle or a little choke is given. I guess what I'm saying here is it's not any more cold natured then any other outboard I've been around and a lot less than some! Even after warm-up with no choke it will not idle at all period! After dying It will restart on the first pull with full choke. With no choke it is a multiple pull and pray operation!!! He is used to this procedure and can manage with little bother but let someone not used to it operate it and it is a headache. Got any suggestions. Please be elementary as I am very limited in my boating basics! In trying give enough info I probably confused some...... Sorry. Thanks in advance for any suggestions!
