9.9 HP Problem
jyanna
I have a 9.9 HP Nissan Outboard. The motor runs perfectly with the cover off, but is very sluggish and low RPM when the cover is on. Any ideas are appreciated.
pvanv
Re: 9.9 HP Problem
What is your model/serial? Model information is in the format NS9.9B2 or NSF9.9C, etc.
You likely have either a bad base gasket where the powerhead joins the exhaust housing (causing the carb to breathe exhaust when the cowl is in place), or a restriction (such as a wasp nest) in the air intake of the cowl, causing a lack of air when the cowl is on.
jyanna
Re: 9.9 HP Problem
I have a NS9.9B2. There is no air intake on the cowl that I can see.
pvanv
Re: 9.9 HP Problem
Not even under the aft tilt handle? The carb needs to get air from somewhere. It must come through either the upper or lower cover, or both.
If you see any smoke at all from near the base of the powerhead, you probably have a blown base gasket.
jyanna
Re: 9.9 HP Problem
Thanks so much for the help. I will check both of those out.
