If I have continuity between the wires with the stop button removed, what could be the problem?
S sadiedaddy Recruit Thread starter Joined Feb 11, 2015 Messages 3 Feb 11, 2015 #1 If I have continuity between the wires with the stop button removed, what could be the problem?
Bosunsmate Admiral Joined Apr 7, 2012 Messages 6,135 Feb 11, 2015 #3 ground is grounding to the other wire too
R racerone Honorary Supreme Mariner Joined Dec 28, 2013 Messages 40,028 Feb 12, 2015 #4 You need to provide a model # -----Maybe there is no problem !
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Feb 12, 2015 #5 What kind of problem are you having with it ??
S sadiedaddy Recruit Thread starter Joined Feb 11, 2015 Messages 3 Feb 15, 2015 #6 model # 104940G or O on the last letter, can't make it out clearly. I can't get it to crank, I think it is grounded out but I am not sure if it suppose to have continuity between the two wires.
Bosunsmate Admiral Joined Apr 7, 2012 Messages 6,135 Feb 15, 2015 #7 Cant get it to crank over or start?
S sadiedaddy Recruit Thread starter Joined Feb 11, 2015 Messages 3 Feb 15, 2015 #8 thanks for the input guys I figured out that they do have continuity I got her purring.
