Re: 9.9 evinrude grease out prop
As far as the compression. It is not bad. It should run well. Of course there are differing opinions and differing compression testers. As far as the prop...why take it off? If you mean that it looks like grease is around the outer prop shaft so what as long as its not oil. They probably greased it a little much but its better than a stuck prop trust me. Ive had blow torch fights where ive cursed the one who didnt add grease. Its a splined prop everything seems fine put it in the water and have fun
