Hi all-
I have a 1980 9.9 hp evinrude that I recently aquired. The motor runs great at slow speed but when I open the throttle it will run at high rpm for a few seconds and then drop to low rpm. If I again return the throttle to wide open, the RPMs go up and then down again. Pumping the primer bulb seems to help somewhat but will not return the motor to full speed. Plugs, fuel tank, fuel line and gas are new and the fuel pump appears to be functional. Also, the motor is being run in neutral with the hose attachement. I want to make sure it works before I get it on the water. Any help would be great.
