Hi guys and gals?
If anyone has some insight that would be great. I was having issues with the motor only starting at high idle and stalling out at low. I took it apart and cleaned it out assuming that it was gum and varnish. However after a couple of attempts to retry it was still stalling out at low idle. I noticed that the little brass ball on the low idle compartment looks stuck? I think with the cap on there is no way for fuel to get in there than if not thru the ball? I removed the cap and installed and fired up right away. However there is too much fuel when throttled up obviously now. My question if anyone has an answer am I on the right track? Is it possible to fix that ball or do I need to buy a new carb? Thanks in advance!
