britabroad
Thread starter- Joined
- Aug 6, 2008
- 19
Hi all, I'm running out of ideas here and getting fairly frustrated.
I have a Merc 180cc Sailpower (basically a 9.8hp from approx 1985), which is only running on its top cylinder.
I've put about 100 hours on it over the last couple of years, and it's always been reliable, until a long 8 hour run recently, when it lost power about half way.
I did some tests and found that the bottom cylinder wasn't contributing at all (pulling the spark plug lead made no difference). This is what I have done to date.
- rebuilt the carb with new gaskets and integrated fuel pump diaphragms
- taken off the exhaust cover and replaced the gaskets (thought the mess on the bottom cyl spark plug might be watery) - also replaced the exhaust baffle as the old one was warped
- tested the compression - both cyl 120psi (when cold)
- checked for spark on both plugs (good),
- replaced the spark plugs
- swapped the ignition coils (just in case one was weaker).
- replaced the bottom cowl to powerhead gasket (collateral damage when taking off the powerhead).
I'm not sure what's left to try. Reed valves? Is it time to give up and get another engine?
