Re: 9.8 merc no spark
Check the insulators where the points wires connect, they crack and leak spark energy to ground. New insulators are cheap and still available.
Points may look burnt but that's common on this "phase maker" type of ign and as long as there's continuity they should make a spark. You can pull them out, take apart, clean to bare metal on a whetstone, degrease and reinstall and they'll be fine. Adjust points gap to .020".
Check the continuity of the kill switch, if I recall this ign has to be grounded thru the kill switch to operate.
New stator rings are available aftermarket but they ain't cheap! Check on this site or try the CDI Electronics links at
www.boatfix.com
Look up part numbers for your motor at
www.dougrussell.com here's the direct link to their Merc Parts catalog:
http://www.dougrussell.com/partscatalog/collections/index.cfm?fuseaction=collectdetails&colid=01
HTH & G'luck..........ed
