Re: 9.5 1967 evinrude compression
It does seem low, but if it runs good, why be concerned? At worst you're just a little low on power from a 30+ year old engine.<br /><br />You may want to try
decarbing it to pull those numbers up a bit. You may also want to try taking the compression when the engine is warm.<br /><br />Good luck!<br /><br />EDIT: Sorry, to answer your first question, there is no spec for the compression for that engine. The most important thing is that there is no more than a 10% difference in compression between both cylinders. 90psi or greater is generally considered very good.
