redjmp
- Mar 16, 2005
- 536
After posting that 1 manifold was hotter than the other, it was suggested that my cooling system was installed improperly.
Originally all I had were the 2 hoses from the t-stat cover running to the bottom of the manifolds. The 4 inlet/outlets in the housing itself were just looped back to each other.
Now I have gone and installed a couple of brass fittings in the risers and ran the hoses from the cover to those.
I ran 2 new hoses from the outlets in the housing to the bottom of the manifolds and looped the 2 inlets together.
Now the risers are stone cold, the manifolds do get hot especially at the bottom but the motor never gets past 120 degrees.
Would it make a difference if I installed 2 more fittings on the manifold and ran return lines to the inlets on the housing?
My merc parts man sugested to do it like I have done but I am not sure.
My clymer book shows 6 lines for this motor but there are less lines on newer motors.
Now these are essentially all the same 305/350 blocks and the risers and manifolds are the same as well( well not really as mine have been replaced with center rise aqua power ones as opposed to the log style rear rise type that came stock) so why were there changes to the design along the way? Theoretically should not all of these configurations work?
I can only assume that the boat ran fine before with all 4 lines from the housing effectively plugged.
But I don't see how it was able to cool anything at all in that state as the t-stat would have blocked all flow going through the cover hoses to the manifold.
Maybe I should run the cover lines back to the manifolds as before and run the new lines from the outlets to the new fittings on the risers?
What do you guys think?
I don't think its running right the way it is now as the t-stat never gets to open.
1st pic is the newone. 2nd is the way it was before.
