89 OMC Crossflow V4 timing?
GatorMike
Ensign
I receintly had a problem with my outboard. Due to too much tinkering everything was out of adjustment. At this point I have good compression, good spark and am getting fuel. I have the throtle cable and throtle valves set right I believe but am having trouble starting and keeping it running long enough to set the timing. Excuse me if I sound stupid (I'm not a mechanic) but is there a proper position to set the spark advance for a starting point? If the initial setting isn't right wouldn't it make it difficult to keep the engine running more than a few seconds?
OBJ
Re: 89 OMC Crossflow V4 timing?
Yep.....<br /><br />Hi Mike.....There's a long procedure for syncing the timing and throttle linkage at low end. I don't know if the whole procedure ever been posted here before. What ya' might want to do is get a service manual, OEM preferred, and follow the procedure. You can get a reprint of the original service manual from Ken Cook Co.<br /><br /> http://ww3.kencook.com/evinrudejohnsonmanuals/ <br /><br />I'm not real sure the generics have got the exact procedure for your engine.
GatorMike
Ensign
Ok I have located the problem. The reason my outboard won't run more than a few seconds is not timing. I am getting no spark to the #1 cylinder. Knowing my wires are new and my power pack is less than a year old I assumed it was the ignition coil for #1 and ran out and bought a new one. Guess what, I was wrong still no spark. I hooked up the wire for the lower right cylinder to the coil for #1 as an experiment and got spark.<br />Sounds like It must be either the stator or the power pack? What do you think my next move should be?
wilde1j
Get a shop manual, first. Wild-a$$ guesses are very expensive. Power packs, stators and timer bases are pricy items. You want to know what's wrong before you start buying parts.
Joe Reeves
Mike.... You have two identical powerpacks on that engine. switch them. If the problem follows the pack, that pack is faulty.<br /><br />Since you have lost ignition/spark to only one cylinder, it is impossible to have a faulty sensor within the timer base. The timer base contains two sensors, each sensor firing two (2) cylinders (1&3 - 2&4). A faulty sensor would cause two cylinders to lose ignition/spark.
GatorMike
Ensign
Joe thanks for the information about the timer base that will be helpful. You are wrong about the power packs though. It is an 89 1.6 litre Sea Drive and has only one power pack.
Joe Reeves
Oooops! Sorry about the powerpack goof. That'll teach me to sit at the computer wearing the wrong glasses. Just glanced at the screen, thought it said 79.
GatorMike
Ensign
Joe, you sound like you know these outboards pretty well I have one more question and I don't think it is related to my problem. I kind of doubt you will be able to answer it with the info you have but here goes. The wireing diagram I have shows 2 purple wires connected to the bottom screw of the bus bar. There are 3 on mine, one of the wires is cut off. I can't figure out where it went to. I suspect about 3 years ago when I rebuilt my power head I removed the VRO and that wire may have gone to it. Would you have any idea what the 3rd purple wire might have been for? The wire was live and It just might have made contact with something and shorted out one of the engine components. By the way I rechecked the spark plug wires and I am getting no spark to both 1 & 3 so it probably is the timer base.
Joe Reeves
Mike.... The VRO would have had a purple wire which would have connected to the other purple wires which are attached to the terminal strip. Strange that the wire would have been cut rather than simply removed. Sounds like you found that those wires are hot when the key's on.
GatorMike
Ensign
Thanks Joe that is what I thought the loose purple wire might have been. I was the culpret who cut it instead of removing it. Those things happen when a non mechanic rebuilds his own outboard. I think I did a pretty good job though. It has been 3 years and hundreds of hours before I had a problem and the problem I am having is not mechanical.
