i_build
Thread starter- Joined
- Apr 24, 2005
- 164
Was running lean at 3k rpms and bad idle after sitting for 7 months. Swapped out the water seperator same issue. Sprayed down the carb with cleaner same issue. Took the top off the carb and the float boals were loaded with crap at the bottom. Cleaned them out and sprayed through the jets, used 2 cans of spray cleaner and cleaned primaries, secondaries, mixture passages, needle and seat... super clean.
She is still idling bad (not as bad... but bad). At an idle when I look down the primaries I can see gas dripping from the left jet (drivers side) but not the right. Does this indicate the float levels are off? I cleaned out the needles and seats and both seem to be functioning properly. At an idle should I be able to see any large gas droplets comming out of either jet?
When she was idling smooth before non-use I never saw large gas droplets just mist.
Any advise appreciated.
