bordercountry
Thread starter- Joined
- Jul 3, 2004
- 2
Motor seems to miss on takeoff when under load. Mainly when trying to pull a skier or when there is lot of weight in the boat. It takes off fine with just me onboard. When under load it seems to not be hitting on all cylinders then all of a sudden it will start sounding better and take off. I had it in to a boat shop twice and this is what they did. <br /> The 1st time in they checked spark and compression - good. No spark on #6 cyl. Checked ignition system and found weak spark on #2 and #4 cylinder and no spark on #6. Power Pack is bad. Checked trigger and stator- checked out good. Replaced power pack.<br />Still did the same thing so I took it in again and here is what they did.<br /> Checked ignition system #1 cylinder has no spark. Checked components and found faulty switchbox assembly (other one) Found bad oil cap sensor-replaced. They also put in a new water pump.<br /> I took it to the lake and it ran fine with just me in the boat. Next day I loaded up the family and with the extra weight in the boat, same problem on take off. Once it catches it seems to run fine but Im not sure if it hitting on all of the cylinders. I also noticed with the extra weight in the boat I am only turning 4400 WOR.<br />Any Ideas what is happening? I am running a 21 pitch prop and am considering a smaller pitch. This may be a stupid question but could the larger prop be not allowing enough rpm's for proper acceleration?
