89 mercruiser 3.0 EST igniton install
I've done a little looking and didn't find what i was looking for, so my apologies if i missed something and make a duplicate. I have an 89 mercruiser 3.0 with the DDIS ignition. For the past several years i've had an issue with hesitation during a hole shot. Even if cruising and rapidly increase the throttle the engine hesitates. I've rebuilt the carb, bought a rebuilt carb, replaced plugs and wires numerous times, changed the pickup coil, set timing, everything, and the issue has stayed the same, did not get better or worse. I had the troubleshooting guide to the DDIS system and all checks are within specs. Finally i read that there are many issues with the system and parts are expensive, if even available and that it's better to convert to the EST ignition system. I have done that and have most installed. My only question is what side of the switch interrupt switch to i connect to. Since i'm not 100% sure how it works or what it does, i don't really know what side of the switch to connect it to. Thanks for any help that can be given.
Fun Times
Re: 89 mercruiser 3.0 EST igniton install
What is the color of the wire you are hooking up to the shift plate?
I believe the answer you are looking for is on page 1C-44 of this link, http://www.boatfix.com/merc/Servmanl/6/6C1R3.PDF
I know Don has a highlight diagram floating around here somewhere with an arrow showing where to hook it up exactly, But I can't seem to find it at the moment. So I hope this works for you.:)
Good luck.:)
Thanks for the reply, It's been a couple weeks since i've looked at it, but there is only one wire coming off the distributor and it's black. I assumed it should go to the ground side of the switch, but i don't like to assume.
fishrdan
The EST ignition uses +12V for the shift interrupt switch, not ground like other ignitions (not sure what the DDIS uses), so you may need to rewire the shift interrupt switch. I don't have a diagram handy, but there might be one up in the stickies.
From memory, I think the shift interrupt switch needs to be wired in with the carb's choke wire, purple wire......
