89 merc 70 horse 3 cyl runs rough
dan_crosby
out fishing the other day trolling boat ran good across the lake then lost most of its power couldnt get it to plane out go it to the launch was puking out foamy oil/water/gas mixture out of the three port exhaust... i changed the gas put new fuel filter on... seems as if its not running on all cylinders... kinda new at working on boat motors is there a trick to checking fire? number 2 plug was wet with gas and number 3 plug was oily and number 1 plug was running perfect any ideas would be helpful! and sitting on the trailer with muffs on it its now puking same foamy mixture out of exhaust on prop
emoney
Re: 89 merc 70 horse 3 cyl runs rough
Just a bump so one of the pros around here see your thread. They fall off quickly around here.
dan_crosby
any help would be helpful thanks
