89 johson 200gt
modsrx38
i got a high idle ...... its not the quickstart it does work perfect ...i check the timing and its ok ...i check the butterfly and they are completly close ...i check for a air leak and cannot find anything ...motor run perfect in midrange and top end ...is it possible that someone drill the butterfly hole bigger than stock ????only way to make it run perfect its to block one of the hole on the butterfly carburator ..that way is possible to adjust the throttle right and engine run perfect at idle .....compression have been raised a liitle not sure if could be the problem .....
modsrx38
Re: 89 johson 200gt
timing is set where it supposed ..if i put more aftdc timing the rpm drop but the engine start to cough at idle .. lickage are all free and set properlly ....if i look at the butterfly carb they can't be more close ....the iddle set screw doesnt touch the case ...start to think that someone drill the 2 butterfly hole in eatch carb..doesnt know the stock size hole ...if i block one hole of butterfly on eatch carb then after that i can adjust the throttle with the screw for idle rpm .....all plugg look fine from iddle to top end im pretty sure its not a air leak it would be seize from all that time ........
Faztbullet
Re: 89 johson 200gt
What is your compression?? Are you trying to set this on a hose or in the water?
modsrx38
Re: 89 johson 200gt
around 125 on my gauge ..in water ....i know water do some back pressure ..still run on premium fuel ....
j_k_bisson
Re: 89 johson 200gt
Ok lets summarize
Need Compression for all cylinders.... !25psi a bit high for this motor. What was the conditions when reading taken?
Not done in water, The idle is high. Idle out of water is around 1000rpm's.
In water and in gear it is 750-800 when timing and linc-n-sync is done.
Does this help?
modsrx38
Re: 89 johson 200gt
thnx joe but this will not make the idle to go further down ...carb are already close at maximum......curious to know if u can make those engine to go lower than 750 rpm with the rpm screw .in gear in water ......anyone know the size hole in the butterfly throttle plate ...mind are just a little smaller than 3/16.......if i can't find the problem i will glue one of the hole on the butterfly carb ....my engine will not go lower than 800 rpm in gear in water .....compression have been raised to give more punch at that motor ...
Faztbullet
Re: 89 johson 200gt
Has it every ran right with the compression raised? How did you raise it? Did you shave the heads or swap to different heads? Is the front air box installed or has inner plate been gutted? Check timer base as some of those models had a timer stop screw on the port side of engine. If all checks out check the hub magnet on flywheel as these are known to slip.....
modsrx38
Re: 89 johson 200gt
thnx i will get a look at the magnet ...they have been swap with smaller cc heads can't remember parts number but many here did it ...i did never run that engine with stock heads ....i will get a look at the magnet last thing i could think ...for now i block one of the hole on the butterfly on eatch carburator ...engine never did run so smooth ..........front air box is all stock with baffle ect ..is it possible to have to mutch wear on every carb ......
j_k_bisson
Re: 89 johson 200gt
Let's get the on this straight. Carb air jets do not wear. Air holes in carb throttle plates do not wear.....
You seam to be asking if the carb holes have been modified from stock to allow for a leaner air fuel mixture at idle. Correct?
The assumed thining here is that the hole in the throttle plates are open larger allowing for more air in the fuel/air mixture. Correct?
Simple to find out, grab some stick tack and plug a hole. Make sure that there is a larger gob of stick tack, so it does not pull thru hole. You can pop a hole in the stick tak and "play" all you want. This will allow you to know if the fuel air mixture is the "key" to lowering the RPM.
But to state something. Nothing wrong with your high idle of 800 rpm's in water in gear. That is right whear it is suposed to be.
If it is a little wrough when idling, you need to identify if it is a lean sneeze or loading up at the timing setting. If it is loading up, might want to check the recirc system, cracked rubber lines giving air leak, or the hoses that comes from the bottom main journal up to top of motor (to atmosphere). See if a spider is blocking this air passage as well.
If this is blocked, then fuel will sit in the bottom of the crank journal and load the motor on the bottom cylinders.
Justa couple of ideas....
modsrx38
Re: 89 johson 200gt
thnx buddy ..well i close one of the hole in the throttle plate on eatch carb and the engine work perfectly .....so i think i will let that way it is .......cannot find why it doesnt want to iddle lower than that if i don't block hole .....i know air bleed doesnt wear ...but im sure the shaft of the throttle plate with years could wear some and give more air .....don't like went a engine is running high on idle it bing bang went u put in gear and reverse
modsrx38
Re: 89 johson 200gt
thnx joe ..will see how it goes with the hole block
