About 6 months after I pulled the boat out of the water for the season, I noticed oil had dripped down the prop and made a small pool on the ground. It looks like the oil originated at the seam of the lower unit. Do you think this is a gasket problem? Should I add some oil? Can it be put in the water and test the motor or will that damage the it ?
Thank you for your advice.
