89 Johnson 25hp Missing
bigfishcatcher3
1989 Johnson 25 J25rlcem
I am struggling to pinpoint an issue with my outboard coughing / sputtering. I can start it first / second pull everytime. Idles great and can troll at low speeds just fine. When I go to higher rpm's I am experiencing severe coughing and sputtering that sometimes will almost throw me from the seat.
Here is a video I took last time out on the lake.
https://youtu.be/B-BsqYwc5LM
I have found and replaced a leaking gas primer line. Replaced spark plugs, bought a completely new gas line from tank to motor. Cleaned carb twice. I did not do a rebuild on the carb, just cleaned it because I did a rebuild two years ago. CDI is two years old.
I am trying to figure out if I am having a spark issue or gas problem. I am guessing spark but I am not sure how to test the spark at higher rpm's with a load. I have noticed minor differences in how the motor runs after cleaning the carb though. After the most recent cleaning it now is guaranteed to sputter at top end. I tried last week putting it in a barrel but could not get it to act up. Not enough load on the motor i don't think. On the lake I cannot go 10 minutes without issues.
One last thing. About a month ago I had my motor seize up on me. What happened is a screw backed out of the stator and was scrapping the underside of the flywheel until it got high enough to lock the flywheel up. The sputtering and poor running was happening prior to this event and I don't believe it is related however I am no expert on motor repairs. Any help is much appreciated. Thank you.
