Every time I want to start my engine through out the day and its Flounder season here so its about an hour or so each time I start it I have to raise the warm up lever fully and turn it over and it starts right up no problems. With out raising the lever it does not want to start. Normal? Or is something out of adjustment with the carbs? I always thought you used the warm up lever first thing just to do that warm up the engine. I dont need to choke it after the initial start up of the day just have to raise that lever every time. One its running I can set the lever right back down and it idles great so need to slowly back it off to keep it running. Normal?
