Fishing Bird
Thread starter- Joined
- Jun 24, 2003
- 1
My '89 Johnson 150 GT stopped charging the battery. I have seen this on other motors and decided (with the advice of a local outboard expert) that the rectifier/regulator was most likely the problem. I replaced the unit but only went from .6 volt at the battery cables to 1.7 volt. Now I think the stator is bad. A ohm reading between the yellow and yellow/gray wire indicates a high resistance . Any ideas where my problem might be?
