89 Johnson 110 hp. Lost power..No top end speed
Dishtech43
I bought this Bass Boat a few months ago..Ran Perfect.and fast.I only had it out maybe 5 times.Last time We went fishing.it ran fine,until we was ready to leave.I started it.it died a few time,when putting into gear..finally took off,and shoved throttle down slowly.but it was like a 1/3 of throttle..wont plain out.Bogged down.Just wouldnt rev up full throttle.after about 1/2 mile down river..it took off! I had to slow it down.ran fine back to trailer. I got home and replaced old gas line and bulb,blew out carbs with drains open, added C foam to fuel..took it out today,and never took off at all..just about 1/3 throttle.tried chocking it and squeezing bulb..didnt help. I brought home.and checked compression. they was from 103-107 .I think I read that was year of low compression heads.I was thinking Power Pack.any ideal guys.Plugs,wires,fuel pump all new.
AEROCOOK
Master Chief Petty Officer
I'd start with a good carb cleaning. My "Healthy" 110 has 120 compression on all 4, your numbers are a little low, maybe try a different gauge.
Dishtech43
oh really..maybe gas and not electrical ! I was thinking Power Pack..but got me thinking..I can t mess them up I guess..lol
AEROCOOK
Have you checked for spark on all cylinders? Can you run it at home with muffs to check? Seems to me that motor has a single power pack that's fairly expensive so you dont want to guess on it. (dont ask me why I know this) At any rate having re-read your original post, checking for spark would be a logical starting point in my opinion.
ondarvr
Check for spark
Look at the coils before a power pack if there's an issue with spark.
Clean the carbs, blowing them out doesn't do much.
Don't run it if it's not running right, if a carb is dirty you can destroy the motor quickly. .
James R
I am in complete agreement with ondarvr. So many times have I heard the story " I bought this boat and the motor ran great for a Short time then it blew up". Were the carbs rebuilt says I. I don"t know or I don't think so says he.
Please folks have your carbs stripped, carefully cleaned and rebuilt with new kits. Todays fuel is killing us. Use Marine Stabil in all fuel and fit a fuel water filter or the dealers will really love you.
Dishtech43
Yesterday..I put Ear Muffs on motor here at the farm.and check each cylinder for spark..with spark tester..all ok..Did Compression test.103 - 107 on all..This year motor was told had low compression Heads..110 Psi When Brand new.. I did take Carbs off and take apart and cleaned them and blew them out..never seen anything in them at all..very clean. ,,but this morning I took it to our lake..and it took right off and planed out every time..I ran it for about an hour.stopping and taking off..It was not planing real fast.but did with in 8-10 seconds..Just seems slow at taking off..I did have one time it did not want to take off and plain. but finally did..and worked of after that one time..Can it be in Timing...? It acts like I need to advance the timing..so it is better..can it still be the Power Pack..Dont really know what that does.but maybe give it more power when needed?
ondarvr
It's rarely the actual timing, but it can be the advance sticking and not moving easily. Power packs can do weird things, but most of the time they work fine, so look at other things first.
If cleaning the carbs helped, and since that's the only thing you may have changed, look a little closer in that area. Carbs can plug up at any time, and needing to clean them a couple of times in a row is not uncommon. There can be gunk in places you can't see, and we don't know how thoroughly you dismantled them, plus it can be re-contaminated by new junk in the fuel line.
James R
A thorough cleaning entails removing the welch plugs in the carb bodies and any jets you can manage, soaking the carbs for at least a half hour, I use Gunk carb and parts cleaner, it doesn't hurt anything. Carefully probe the idle tubes with a fine wire and shoot carb cleaner through the tubes and jets. Rinse under running water and carefully blow dry using compressed air. I then run them through my ultrasonic tank with a good dilution of simple green. This may be overkill but thats just me. Rinse again and blow dry. Use a pen light to look through the tubes and orifices. Replace the welch plugs, they come in the carb kit. Rebuild careful to set the float levels correctly. I hate to have to take a carb off a second time.
