Getting ready to re-assemble. Checking details. So I'm using loctite 518 to assemble the crankcase. It's supposed to be the modern equivalent of OMC gel-seal II. The J/E manual states to prep the mating flange side with this primer. After some online reading, I learn that the primary use for loctite primers when using their anaerobic sealant is to speed up cure times. This engine will sit for at least a week before I attempt to fire it. What say the more experienced J/E engine builders here? Is this stuff really necessary? Thanks in advance. Been a member of this forum for years and have always found reliable trustworthy help here. Kevin
![20170505_205927[1].jpg 20170505_205927[1].jpg](https://forums.iboats.com/data/attachments/253/253157-e3d056ea95b09da8d7b377bda31d77bf.jpg)
![20170505_210159[1].jpg 20170505_210159[1].jpg](https://forums.iboats.com/data/attachments/253/253159-b73c19ad4ffbe0aab230a151bbe8eabd.jpg)
