89 gt200 stlceb
Bamariver
Got new (new for me ) boat last year. When I got it the lower was cracked and I couldn't run it but it was a good deal. I already had lower from my old bass boat and figured I was ahead. $1500 later I'm not ahead. I replaced lower and went to test. Motor turned over wouldn't crank . Cut to the point. New flywheel, power pack, plugs wires timing advance arm,timer . Got it running. Cranks idles runs . Wouldn't plane. Take back to shop. 2 months later and more money we are good? Take back to river runs like singer sewing machine. Next day crank run fish and restart back to will not plane. I just ordered temp switchs because I read that this will limit to 2500 rpms . If anyone has something I've missed let me know. I also have checked fuel lines but will replace any way. Vro was bypassed when I got it so I mix 50:1 with non ethanol. Any ideas on what the problem is? It has put a halt to my fishing. Thanks for any suggestions.
Faztbullet
Tap the key to "choke" it as your trying to plane, if it planes out carbs need rejetted or fuel pressure is low also 1989 models had chitty carbs.There was a TSB on changing intermediate jet smaller on these models..
