Re: 89 glastron futura 237 sl bad transom need advice???
No paint. It has the original gelcoat and needs a good polishing as well as some whiskey dents fixed.
I'm glad you decided to tackle it. It would be a shame to send it to the dump. I've seen pictures of your model. If yours is the same as I've seen, I envy that glassed floor. If you don't have a bunch of unsealed extra holes and screws in the floor, your stringers are probably fine. That's what killed mine. The previous owner screwed in a 2nd layer of ply over the old stuff. You can inspect the rear section of the stringers without cutting the floor. They butt up to the motor mount blocks. Drill a few test holes. The transom on mine is relatively small and doesn't run the full width of the boat. It spans the distance between the 2 inside stringers and doesn't extend beyond them. If your stringers are good, the transom should come out easily without having to cut into the floor. If the stringers are bad...well, that's a different story.
Please post some pictures.
BTW, these boats haul backside don't they!
I get a kick out folks who try to run me only to find out this old boat walks away quick. I'd imagine your BBC really moves out.
