duckhunter89
Thread starter- Joined
- Apr 19, 2011
- 6
from the top new....head,plugs,water pump,gas can,primer clean the carb has 110 on both cylinders on compression test gets fuel but when i go to pull start it there is a hole in the mid section right above the lower unit and gas flows out of it when i pull. pulled the lower unit and gas is coming out of the exhaust will not run need help!!!!!
