'89 Force Boggs sometimes
tomslik13
My 85hp force Idles alittle rough and sometimes boggs down when I stand on it. This will happen around 7-8 times per outing. Other times runs just fine. When I put new plugs in It won't happen for 1-2 hrs. I always use the same mix. and high end gas. Any Ideas?
Jango
Re: '89 Force Boggs sometimes
I had similar problem with my 1988,85HP Force. Corrected by, slightly richer idle mixture - 1/8 to 1/4 turn CClockwise on Mixture screws and don,t use Premiam gas - causes more ash. to foul plugs. Use a good Quality 87 Octane gas and oil at 50:1. (preferably "Pennzoil Senthetic Blend" - you can get at Wal-Mart)
