Re: 89 force 85 timing marks
Static Engine Timing
1. Remove spark plugs from the engine.
2. Connect a spark tester or spark board to all spark plug wires. This will
prevent the outboard from starting during the test.
3. Remove the propeller.
4. Attach a timing light to the number one cylinder.
5. Shift engine into forward gear then to the wide-open throttle position.
6. Crank engine over while aiming the timing light at the timing marks and
note the reading.
7. The timing should be within the specifications given in the "Tune-Up
Specifications" chart.
8. Make any necessary timing changes by adjusting the timing rod connected
to the trigger housing.
9. If necessary repeat the max timing procedure until the settings are correct
