'89 Force 50hp 507X9B wiring
Jerry Arbs
Found these two (one was previously soldered) wires and am not sure if theyshould be connected. I was inspecting because my power trim has been acting up. Yesterday it wouldn't go down, reset the small breakers, and it seemed to fix it. Now today it won't go UP. Tried the breakers, no go. Both relays seem to function, also swapped them back and forth.
Any idea if those wires are related? Seems they come from the stator area. Any help at all would be truly wonderful. Wiring diagram? Seems like a lost cause to find one.
kbh121956
Brown/blue and Brown/yellow are both wires that come from your #1 and #2 module. They go to your Stator.
Jerry Arbs
Thanks kbh121956, do you suppose they should be connected to each other as it seems like they may have been?
jerryjerry05
I don' think they go together.
The T@T wires are blue/up green/down
Just because the relay clicks doesn't mean it's good.
Unhook the blue green wires from the relay.
Hook one to ground and the other to positive.
That should make the motor turn.
Then change them around, that should make them turn the other way.
He only has 1 pack.
Try to find a factory manual.
It has the wiring diagrams for your motor.
kbh121956
kbh121956 any idea where specifically?
Yes the brown wire with the blue and back stripe goes on the very bottom terminal screw (not the screw that hold the buss to the block). The other wires goes on the next screw up on the same buss bar. Both these wires go to your stator. It won't run without them. They do not go together. I wish that I could send pics but can't. I PM'd you.
