chris beougher
Thread starter- Joined
- Apr 29, 2009
- 2
I have a 1989 force 50 hp on a maxum I bought at the end of last summer. When purchased the boat had sat for about three years prior to my purchase. After purchasing I changed the impeller, drained all gas, new fuel lines, new plugs, and new float in the carb. This is my first boat and do not know a whole lot about the motor.
The motor starts and runs very smoothly but will not get over 5 maybe 10 mph. I do not have a tach on the boat so can not tell you how high it is running. I was wondering if anyone had any ideas. From reading through other forums I was thinking it maybe a fuel problem still because when i take the fuel line off of the carb and turn it over it is not coming out in a steady stream. But also the bottom spark plug has NO build up on it the electrode looks as though it has been firing but have not had a chance to get a spark tester. and also the bottom cylinder after i took the cover off looked clean. Any ideas as to where this power loss maybe coming from?
