sebringguy77
Thread starter- Joined
- Oct 3, 2010
- 2
I have a 1989 force 150. I am in the process of re-adjusting the linkage. Was wondering how high my Rpm's should go when i use the warmup lever? Last time i took it to the lake it would only throttle up to about 2000rpm. Is that maximum? seems to hit a plate on shifter linkage in bottom of cowl. Is that normal or do i have to do some adjusting? I have the shift linkage adjusted perfect. Also, On the top of the timing bar. There is a screw adjustment. i had to replace the plastic piece and i dont know how far to set the adjustment screw. Is that where i set the timing to 28 degrees btdc? Can anyone help me?
