smokeysworld
Thread starter- Joined
- Feb 25, 2008
- 2
I have a force 150 that last summer stuttered on me and when I would go to take it to high rpms it vibrate very violently. I found that the water pump housing was broken. I replaced that and the vibration went away but now I can't get it to get to the higher rpms. I starts and runs fine but when I go to throttle it won't go. I do believe it is an ignition problem of some sort but wanted to see if anyone else on the forums have had a similar problem? Any help is much appreciated.
Another problem it had to is that when I would turn the key off the motor would continue to run for 15-20 seconds later.
Thanks in advance for any help and/or advice
