gillisfire20
Thread starter- Joined
- Sep 6, 2009
- 3
First let me say thank you to all members here. Been a lurker for a while and learned some great stuff. Unfortunatly, this time, I'm stuck. I have a '89 force 125 on a 89 bayliner capri. We were out last weekend running along fine, then she bogged down and died and would not restart. Fast foward, I believe she over heated and the buzzer was inop. I changed the impellor and thermostat with help from reading on this forum. My problem now is that I can not tell if it is working correctly. I had ear muffs on and set the motor in a large bucket of water. I ran her for a while and could not tell if it was pumping water so I pulled the thermostat off and found the inside to be bone dry. I am wondering if there is a clog some where or is this normal. The motor starts up one the first try but runs ruff and after a while dies out. Can I run some sea foam in the fuel and use carb cleaner at the same time.
