89 Force 125 prop/lower unit question
gregmsr
Hey guys,
With spark plugs out and placed in forward gear, how easy should the prop be turned by hand?
I'm concerned with mine as I tried this and was hard to turn and I hear a tight sounding noise inside mid section of lower unit. Sounds like dry rubber seal on a shaft. Is this a normal sound when turning shaft out of water? The prop turns easily when in netural but when in gear hard to turn and sounds squeeky, almost gritty. Is there a seal that tight around shaft?
eurolarva
Re: 89 Force 125 prop/lower unit question
It should turn hard and the sound you are hearing is the impeller turning in the water pump which is rubber.
gregmsr
OK, thanks for that guys. Shewwwwu. I can pretty much do anything with a car engine but O/B's i'm learning fast. I'll try not to load up this message board with too many questions.
Thanks again!
Greg Montgomery
I've never done this before but I did stay at a Holiday Inn Express last night!
roscoe
"I'll try not to load up this message board with too many questions."
Load it up. That's why its here.
Thats how we all learn.
And we are making an archive for all the future visitors.
