FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
it very well could be a coil. trigger or a module, id start first at the trigger those thin wires going into trigger have a problem with breaking at the point where they connect into the trigger grab a vom meter and measure the ohms on the four pairs of trigger leads you should read between 45 to 50 ohms on each seperate pair of leads if you read zero ohms you got a trigger problem
Thanks for the reply chitown. I'll try that when I get home. To diagnos a bad coil, can I just switch the one I think is bad with a good one? Or is that a bad idea? Thanks
yep thats the way to check a coil, swap it with a working one and see if you get spark, if ya do get spark you got a bad coil, if not you got issues somewhere else good luck
