89 evinrude wiring around the power pack
WT2
I just put on a new power head and am having issues finding where one wire goes. it is a brown and yellow wire associated (taped together) with a brown and white one coming from the red plug one wire goes to another plug going to the power pack and the other looks like it will only fit in the bracket where the rectifier hooks up due to the size of the connector and the natural bend of the wire. I thought I took that entire system off as a unit. I just would like to know where it goes so I don't cause havoc with the electrical system. The wiring diagrams I have are not showing me this wire
Honorary Supreme Mariner
What motor ?------What powerpack part # did you order.----From a dealer or from an " online " parts seller ?----Why are you replacing the powerpack.-----Just hoping it is the part needed ?-----Any testing / trouble shooting done on your motor ?
WT2
70 hp evinrude. my question is focused on where the brown wire with white stripe connects
Model #----A 1974 model or a 2001 model ??---If you answer the questions perhaps I can help you.-----Otherwise I just step aside.----Normally the wires plug in.-----But I have no clue what you actually have in your hands !
