SoTxFisher
Thread starter- Joined
- Jul 16, 2017
- 27
Did a carb clean, had some idling issue where #2 cylinder was not firing.. got carbs cleaned good, engine is idling decent now, but in the instructios for carb cleaning and adjustment.. it states to hold the carb upside down/right side up to and blow compressed air thru to test that its working.
States to adjust float bowl so it is in line with carb body.. where is this adjustment? do you bend the tab? also, noticed the float needle has no o-ring on it, and seems to just fit into the jet loosely....is that normal? Also notice the float pivot point really has no spring to it.. other carbs I have worked on (non-marine) have a springy-ness to it.. is something missing?
thanks in advance..
thanks in advance..
