89 Evinrude 40hp starting
rheller
Have a 1989 Evinrude 40hp on our pontoon. Starting this motor has always been odd in my opinion, and hope to hear what others have to say. When trying to start, it sounds as if the battery is only half charged, turns slowly and almost cuts out for a second, but always starts. It has done this with multiple new batteries charged on charger outside of boat. However, if we hook the external battery charger/starter to the battery while trying to start the pontoon, if fires right up and sounds like a normal engine does cranking. Its almost as if the battery doesnt put out enough amps to start the motor and needs help. we use a 700cca battery and have tried numerous other known working marine batteries with same effect. Is the starter drawing that much or is it something else possibly?
flyingscott
Clean all the electrical connections and pay close attention to the grounds.
Rustywrench
You mentioned it is a pontoon. Is the battery a long wY from the engine (under console)? Are cables factory or home built & adequate size? Longer cables require lager gauge. Just an idea.
rheller
battery is right next to motor in a case. they are the factory cables, not long at all. Connections are all clean and good. Is there any way to test a boat starter?
jakedaawg
No, have the battery "load tested". Parts stores do it free. 700cca is perfect. Chargers tell you nothing. Voltmeter tells you nothing. If you can hook a charger to the battery and then it does fine the problem is a battery.
nobody ever believes...load test is the only definitive battery test.
boobie
Take the starter into a rebuild shop and have it checked out.
